Soren Kelly
I've just ordred 2 5m cables at thomann
well i dont intensionally having one you can check my settings here in the attached file i have 10 pages, 2 for each of my main 5 presets@rjmmusic
I've got the "wrong bank" issue going on right now.
I'll leave my rig in this state, for a while. Tell me if you want me to do something.
Here's a video:
Dropbox - File Deleted - Simplify your life
www.dropbox.com
Is it possible that an IA action with a "System / Song" command, or with a "System / Preset"command, causes the issue to appear?
@Soren Kelly , do you have such a command programmed?
More facts: while the GT in this "bank mismatch" state, the error does not occur when switching presets on the front panel of the Axe-Fx.
If you need schematics for the box, please let me know. I didn't find any issue with your settings during the week I ran them, so I've now switched to Alexander's settings, because he's seeing a similar problem. No issues yet, but I only loaded them about 2 hours ago.Right im now on just pure old midi cables, no hickups at last nights session, so just keep testing with these standard cables - took out all other cables and checked them no fault there....if this works next steb will be building a shielded box with 6pin xlr and 2 midi
Hey i havent had it to happen yet and i have had a few sessions and som live playing så that leads me to the 6 pin cable or the midi cable from axe to 6 pin could you forward me the schematics and i will rebuilt the whole thing again...If you need schematics for the box, please let me know. I didn't find any issue with your settings during the week I ran them, so I've now switched to Alexander's settings, because he's seeing a similar problem. No issues yet, but I only loaded them about 2 hours ago.
Interesting, so are you running with 2 MIDI cables right now?Hey i havent had it to happen yet and i have had a few sessions and som live playing så that leads me to the 6 pin cable or the midi cable from axe to 6 pin could you forward me the schematics and i will rebuilt the whole thing again...
cheers
Yes running 2 midi cables but run ingen the power from the 6pin xlrInteresting, so are you running with 2 MIDI cables right now?
Attached is the diagram for the box. Please let me know if you have any questions.
Hey i got a new box done after your diagram and it has been working flawless for 4 days today at band rehearsel it did it againYes running 2 midi cables but run ingen the power from the 6pin xlr
If you're looking for a 6 pin XLR, it doesn't look like Thomann sells them. They're not common, I don't know anyone aside from us that uses them. The only ones I know that make the cable are Best-tronics here in the US (www.btpa.com)Can you link to a recommende cable at thomann
I have the connectors i just want to make sure i have the right cable quality i was searching through old massages because i thought somebody linked to the actual cable in my search i realized the the issue started the 9th of may 2021If you're looking for a 6 pin XLR, it doesn't look like Thomann sells them. They're not common, I don't know anyone aside from us that uses them. The only ones I know that make the cable are Best-tronics here in the US (www.btpa.com)
I am using the 2 din connectors on the axe and running them to the female 6pin xlr - if i use to standard midi cables from in and out on the axe and down to standard midi in out then i havent seen any issuesBut, have you ever connected to the DIN connector instead of the XLR?
