Shaun Bishop
I've been using the GT/10 with the Axe-FX III for a while with no issues, worked great.
Got a Kemper a few days ago and tried to hook the GT/10 up to it and am having tons of problems.
Before diving into the below, is there some kind of known issue with latest Kemper FW I'm not aware of? I'm on the lastest non-beta OS 5.7.8
* At first the Performance name wouldn't show up on the main display, it was blank. Although the footswitches that I programmed would behave accordingly. I did a factory reset and that seemed to change that, however now the Rig name is displayed in the main display, and I'd like the Performance name. Is that possible?
* In the software editor, I will right click on a button and change it from the default, to say Slot 1, and it will ask me "Do you want to change this to Instant Access" to which I reply yes. Then instead of assigning it to what I told it to, it's just 'off.' Ok, so I do it again. Right click, it asks me the same question, and I say yes. Then for some reason this time it sticks. That button is now assigned to Slot 1. I go through and do that for all the buttons, then write changes to the device, and bam. Nothing on the GT changes, and the screen on my editor goes back to all the default stuff before I spent all that time changing it. And now the GT disconnects from the kemper and PC.
I'm hoping there's some trick you have to do when setting this up to a Kemper that you didn't do with an Axe that I'm missing. Thoughts?
setup : Midi In/Out on Kemper going to RJM Phantom box with the 1 7-pin cable going to the mastermind. Just like the Fractal.
