Kemper tempo to RJM
Brooksbell
A little confused on what to set the tempo to in the RJM editor. I want the tempo to send to the rJM to be the same that's on the performance. Seems like the first time I switch to a performance I programmed in the RJM editor, I have to tap the right tempo. It's set on "song" right now. Is that right?
If you want the tempo on the GT to flash in time with the tempo coming from the Kemper, pick a button on the GT, edit it, turn on Flash w/ Tempo and turn off Send on Preset Change and Update on Preset Change. That button will flash with the Kemper's tempo. You can also turn on Calculate Tempo from flashes in Global settings and Show Tempo on the button - this will give you a BPM value on the display, but the tempo flashes from the Kemper are not terribly accurate and that number will vary a bit.
