tired_engineer
Got my GT tonight. :shock:
So far everything is working as hoped except for the 250K VP Jrs I was using with my old controller aren't behaving properly as far as sweep is concerned. Working on that one. Edit: Solved that one. Polarity is reversed from my last controller. All good now.
A possible suggestion for a future update:
Rather than long pressing the two little buttons up top to enter set-up mode, would it be possible to have a long press of any given preset or IA button allow you to go directly to the setup of that function. This would save a couple steps to get to the editing function for presets and IAs and, especially for presets, facilitate much faster editing of the PCs going to each device etc. Saves you from bending down and also saves wear and tear on those little pushbuttons which I can already see people are going to be using their feet to access. There are plenty of extra spots open to implement the "Done" command on a footswitch in these cases.
Now back to programming....
Oh another one. When buttons are grouped, it would be nice to still have the option of turning the active one off, independent of the others. I tried to group my three delay pedals ( ) but that results in one always having to be on. I'd like to be able to turn my long delay off when I hit the slap echo but would want to turn all delay off at times. I know the grouping is focused on channel switching but it could also be useful for effect grouping if the above could be implemented.
