Here's a new release for you, with some bug fixes and user requested features. Please test it out if you have the time!
FEATURES:
BUG FIXES:
TO UPDATE FIRMWARE:
- First, back up your settings to a flash drive or computer! If you go back to 4.2 or earlier, your Mastermind will factory reset.
-OR-
- Use the Transfer / Update Firmware menu option to update the Mastermind. This works with the PBC/6X and PBC/10s made after March 2019.
Firmware: http://www.rjmmusic.com/downloads/PBC/MM442.zip
Mac Editor: http://www.rjmmusic.com/downloads/PBC/MastermindEditor-4.4.2.dmg
PC Editor: http://www.rjmmusic.com/downloads/PBC/MastermindEditor-4.4.2.zip
PBC/6X Manual: http://www.rjmmusic.com/downloads/PBC6X/PBC6X Manual-4.3.pdf
PBC/10 Manual: http://www.rjmmusic.com/downloads/PBC/PBC Manual-4.2.pdf
Editor Manual: http://www.rjmmusic.com/wiki (not yet updated for 4.4)
FEATURES:
- Support for Strymon Iridium, Chase Bliss Blooper and Mood
- Tapped in tempos are now preserved when switching presets within a song, if preset tempos are set to Song, or if "Ignore Preset Tempos" is turned on.
- Added two special values to the ExpPedal action: "Same" does nothing, and "Send" sends the expression pedal's current value again
- "Decimal Tempo" setting controls whether tempos are displayed with one decimal place or as whole numbers only
- Added setting to reverse Bank MSB and Bank LSB CCs for incoming bank selection
- Added the ability to enable the Tuner Out on the PBC/6X itself
BUG FIXES:
- Loops and other audio features can now be controlled over USB
- A button that controls multiple loops will now update the state any other buttons that control the same loops
- Fixed button name display in IA Mode
- Hid a lot of options that don't apply to the PBC/6X
- Turning on "Update on Preset Change" on a button will now disable state updates from an Axe-Fx III, like it does on previous models
- Kemper tuner and tempo now work even if Ignore Incoming CC is turned on
- Fixed state update of Kemper Reverb button
- Fixed a bug that prevented long Sysex messages from being sent over USB. (This happened when using more than one Sysex action to build a longer message)
- Fixed Axe-Fx tuner that was off by 1 cent
- Fixed warnings when running editor in MacOS Catalina
- Fixed potential memory corruption issue
- Added support for Jackson Audio Bloom and Broken Arrow V2
- Fixed a bug that prevented PBC/6X insert loop from working correctly when set to mono in / stereo out
- Fixed a bug that prevented tapped tempos from being preserved when switching between presets in the same song
- Fixed Preset -/+ buttons - they were not updating the preset button LEDs correctly
- Tap tempo flashes now work when set to MIDI clock slave
- Fixes to copy & paste in editor - hold & cycle data are now copied correctly. Copying to and from local pages works now. Copying global buttons should no longer cause trouble.
- Added support for Source Audio Collider
- Fixed System / Setlist up/down actions to skip empty setlists
- Group actions would not execute on power up if all buttons were off in the group. Fixed it so that group actions always execute on power up, regardless of state.
- Fixed sysex send over USB (again)
- Fixed right-click menu in editor
TO UPDATE FIRMWARE:
-OR-
