Another new release for you...
FEATURES:
BUG FIXES:
- First, back up your settings to a flash drive or computer! If you go back to 4.2 or earlier, your GT will factory reset.
Firmware: http://www.rjmmusic.com/downloads/MMGT/MMGT451.zip
Mac Editor: http://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.5.0.dmg
PC Editor: http://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.5.0.zip
Manual: http://www.rjmmusic.com/downloads/MMGT/Mastermind GT Manual-4.3.pdf (update coming soon)
Editor Manual (not updated for 4.4 yet): http://www.rjmmusic.com/wiki
FEATURES:
- (UNTESTED) Support for Fractal Audio FM3 and Strymon Compadre. Please let me know how these work for you!
- Dev PC -/+ and IA buttons that select presets on devices can now be linked together so that selecting one updates the other. Any time a PC or bank message is sent to a device - for any reason - the Dev PC buttons will update to reflect the new numbers. If an IA button has a CC0 or CC32 action followed by a PC action as the first two messages, or just a PC action as the first action, and IA Link is turned on, the IA button will respond to other IA buttons and the Dev PC -/+ buttons. For example, a button that sends PC 10 to a device will automatically turn on when PC 10 is sent to the device, even if it was sent by another button.
- The MIDI Merge setting has been broken into In, Out and USB settings. You can use these to choose which ports are forwarded to the output, and which aren't. If you were merging from the In to the Out port, you will have to manually turn on the Merge: In setting after upgrading to this release. The Out setting is new and allows the input side of the bidirectional MIDI Out port to be forwarded out the MIDI Out port, which wasn't possible before.
- When MIDI Receive Channel is set to something other than None, incoming CC119 messages on that channel will change the page number on the GT. CC 119, value 0 will select page 1, CC 119 value will select page 2, etc. This CC number is not user configurable yet, but will be in a later release.
- Axe-Fx channel select menu now highlights the currently active channel name.
BUG FIXES:
- Fixed editor drag-to-swap feature - it didn't work correctly when dragging to external switches
- Fixed some CC values for Strymon pedals
- Fixed special characters in preset, song and setlist names - for example, you can put a '\' character in a song name to force a line break (primarily useful if you have "Show Song Name Only" turned on)
- Fixed scrolling of file names when loading settings or selecting a firmware file to upgrade - you can now select from a list that's longer than the screen can display all at the same time.
- Fixed IA Cycle Menu to correctly show which option is currently selected
- Fixed scene handling to update scene buttons properly when switching to a local page
- Fixed Auto setting for MIDI clock - it wasn't working when receiving clock over USB
