Here's a new release for you, with some bug fixes and user requested features. Please test it out if you have the time!
FEATURES:
- First, back up your settings to a flash drive or computer! If you go back to 4.2 or earlier, your GT will factory reset.
Firmware: http://www.rjmmusic.com/downloads/MMGT/MMGT443.zip
Mac Editor: http://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.4.3.dmg
PC Editor: http://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.4.3.zip
Manual: http://www.rjmmusic.com/downloads/MMGT/Mastermind GT Manual-4.3.pdf (update coming soon)
Editor Manual (not updated for 4.4 yet): http://www.rjmmusic.com/wiki
FEATURES:
- Added "Update Preset Name" button type - pressing this updates the current preset name (and scene names, if applicable) from the connected device (typically Axe-Fx)
- Support for GFI System pedals: Cabzeus and Specular Tempus. Also support for Strymon Iridium and Chase Bliss Mood
- Added ability to update device firmware from editor. Only works with devices that have 2.0 bootloader (built June 2019 or later)
- Tapped in tempos are now preserved when switching presets within a song, if preset tempos are set to Song, or if "Ignore Preset Tempos" is turned on.
- Added two special values to the ExpPedal action: "Same" does nothing, and "Send" sends the expression pedal's current value again
- "Decimal Tempo" setting controls whether tempos are displayed with one decimal place or as whole numbers only
- Added setting to reverse Bank MSB and Bank LSB CCs for incoming bank selection
- Added sysex message to be able to post a message on the main screen
- Doing Assign CC of an Axe-Fx III effect block in the editor now automatically adds the "hold to select channel" functionality, like it does on the GT itself. This works when right-clicking on a button in the Buttons tab and selecting "Assign CC" or "Assign Default Buttons".
- Turning on "Update on Preset Change" on a button will now disable state updates from an Axe-Fx III, like it does on previous models
- Fixed screen formatting issues in calibrate menu and channel select menu
- Fixed bug that kept Get Preset Names running after it was cancelled
- Kemper tuner and tempo now work even if Ignore Incoming CC is turned on
- Fixed state update of Kemper Reverb button
- Fixed a bug that prevented long Sysex messages from being sent over USB. (This happened when using more than one Sysex action to build a longer message)
- Fixed a bug with "Send Off Msgs" group setting
- Fixed a screen bug that caused scene name to flash
- Fixed editing of special values in the GT setup menu
- Fixed Axe-Fx tuner that was off by 1 cent
- Fixed occasional crashes in Update Preset Name
- Update Preset Name no longer changes the stored page number in the preset
- Fixed data corruption on button page 10
- Fixed missing scene name display when using Preset -/+ buttons
- Fixed warnings when running editor in MacOS Catalina
- Fixed a bug that caused problems if you had normal IA and IA cycle buttons with the same IA ID.
- Fixed a bug that caused Poll State to interfere with Update Preset Name
- Added Source Audio Collider and Jackson Audio Broken Arrow and Bloom support
- Fixed scene name appearing in bank selection mode
- Fixed Copy / Paste buttons in editor so that it works correctly with local button pages
- Fixed "Swap Pages" so that it swaps IA Cycle data correctly
- Fixed send of multiple block sysex messages over USB (again)
- Fixed editing of cycle settings on local page of global preset
- Fixed tempo flash when MIDI Clock is set to Slave
- Fixed right-click menu bugs in editor
- Group actions now work correctly on powerup - before, only groups that came up in the "on" state would send their messages. Now, group actions will also send if the group powers up in the "all buttons off" state.
- Fixed System Setlist Prev and Next actions to skip empty setlists
