Hi Ron, got. the update 4.6 done. Problems are solved.
How Did I communicate With the pedal pro ex?
in Mute Mode (cc39) the Tuner doesn‘t appear...
Do i forget anything? Do i have to Make any special settings First?
best M.
Eventually, yes, but I can't say when at this time. It would be a fair amount of work, judging from what it took to implement other devices that needed custom support. It would be helpful to know how many people would benefit from this work - does anyone else here have a PedalPro?Would it be possible to implement the Tuner Function and geht presets names? Would be Great for me. Best M.
What was the excessive power draw thing about? Just curious.
When will the Jackson Audio Golden Boy and Asabi be added to the Device list? Also, any idea when the Walrus Audio - Mako series be added as well?
It's located in the Edit menu.. It can only be edited using the editor, you can't edit or view loop names in the device itself.I'm trying to see where the "Audio Feature Names" menu might be. I don't see it in the manual so I checked in the 4.6.0 Mac Editor but I don't see anything . I then went to the setup in my actual PBC but I don't see it either... could you please tell me where I can do that ? thanks a bunch ... and sorry for my ignorance
Hey Kamil,I'm trying to see where the "Audio Feature Names" menu might be. I don't see it in the manual so I checked in the 4.6.0 Mac Editor but I don't see anything . I then went to the setup in my actual PBC but I don't see it either... could you please tell me where I can do that ? thanks a bunch ... and sorry for my ignorance
Oh ok great thanksIt's located in the Edit menu.. It can only be edited using the editor, you can't edit or view loop names in the device itself.
That's what eventually worked for me, but it took a few tries. Thanks.That's weird. If anyone else sees thsi, please let me know. The firmware update code didn't change in 4.6.0, so I'm not sure what would cause that.
