eljodon
Hi, I just purchased the Mastermind PBC and I'm planning to use it with the Mini Effect Gizmo on the same pedalboard. I would like to know if you have any advice on how to run the ISP Decimator G string pedal. I'm moving from the Effects Gizmo which I used to use with all my pedals with 2 rack drawers, but I'm confused on how to plug it with my new system. I basically use the ISP just for my pedals by plugging my guitar into "guitar in" and the "Dec out" to my amps and using the "Guitar out" to the input of first pedal and the "Dec in" to the out of the last pedal, since I need the Mini Effects Gizmo for a few more extra pedals, I would like to know the best way to plug the ISP Decimator G String into my system.
I'm using a 4 amp setup with an Ampete 444 going into a Suhr Reactive Load which goes into a 12 loop Effects Gizmo so I can switch out a Hush Super C and various eq's and a Axe Fx 2 for effects and Sound Sculpture Volcano for volume pedal and different levels of boost. Hopefully I'll be able to get all working together once I can figure out the Mastermind PBC. I'm trying to make my system smaller with less rack stuff.
