The MIDI Solutions Thru or Quadra Thru are probably the most commonly used ones, and they work well.
Thanks Ron...
Hey Ron, updated to 4.0.1 last night. I run in setlist mode, with tempos set per song. All presets are configured to use song tempo. This morning they changed a tempo on me. I went into the PBC menu to edit the song and change the tempo from 110 to 112, and it was incorrectly listed as 122.0. It would not let me change the value at all.
Luckily I had my laptop with me and was able to use the editor to change the song tempo and update the device. Have you seen this before? Am I doing something wrong or could this be a bug?
Perfect.Right-click the preset on the left. You’ll see copy from preset / copy to preset.
That's the bug I'm most worried about. I need to be able to change on the fly, especially for a couple of songs that change tempo mid-song.I’ve been using it since a few days after its release. The only issue I’ve had is that I can’t change a song’s tempo on the PBC itself. Ron is aware, but I haven’t gotten any additional feedback since I reported it.
Restating the issue I found:
I have tempos set per song, and all presets are set to use the song’s tempo. I can modify the song tempo in the editor just fine, send to the device, and everything works great. But the PBC won’t let me change the song tempo on the unit itself.
So if you upgrade, make sure to bring a laptop with you for any potential tempo changes.
Thanks for the purchase!
Offsets are in cents, capo is specified in semitones.
Hi Ron,
Got my PBC talking to my pedals and original AMP Gizmo just fine but am running into a problem. Not sure if it's the new SW or my old Amp Gizmo.
But, when I start programming presets beyond the 3rd PBC bank (i.e. beyond preset 15), my Amp Gizmo starts getting confused and SEEMS to start using PC settings from Alternate presets which happen to be placed in Bank 3 (i.e. Presets 11-15).
I originally made the mistake of copying presets from one location to another WITHOUT restoring the original destination PC number and thought THAT was the problem. But, restoring original destination PC number and even assigning a specific Amp Gizmo Preset Action to make sure the PC numbers were not getting swapped or confused did not fix the problem. It almost seems like my original early model Amp Gizmo "wraps around" (or "punts" in some way) in response to PC numbers beyond 15.
I don't have any details docs on that early Amp Gizmo so thought I'd ask here. Any idea what's happening?
Dave
Hilton, NY
I don't know anything specific that would cause that. The original Amp Gizmo has 128 presets, so it shouldn't wrap around so early. Did you try going to the Devices tab and clicking on "Set Preset PCs to Sequential" on the Amp Gizmo device? That will restore all PCs to the default (1, 2, 3, etc in sequential order)
