Another new release for you...
FEATURES:
BUG FIXES:
TO UPDATE FIRMWARE:
- First, back up your settings to a flash drive or computer! If you go back to 4.2 or earlier, your Mastermind will factory reset.
-OR-
- Use the Transfer / Update Firmware menu option to update the Mastermind. This works with the PBC/6X and PBC/10s made after March 2019.
Firmware: http://www.rjmmusic.com/downloads/PBC/MM450.zip
Mac Editor: http://www.rjmmusic.com/downloads/PBC/MastermindEditor-4.5.0.dmg
PC Editor: http://www.rjmmusic.com/downloads/PBC/MastermindEditor-4.5.0.zip
PBC/6X Manual: http://www.rjmmusic.com/downloads/PBC6X/PBC6X Manual-4.3.pdf
PBC/10 Manual: http://www.rjmmusic.com/downloads/PBC/PBC Manual-4.2.pdf
Editor Manual: http://www.rjmmusic.com/wiki (not yet updated for 4.5)
FEATURES:
- (UNTESTED) Support for Fractal Audio FM3 and Strymon Compadre
- Dev PC -/+ and IA buttons that select presets on devices can now be linked together so that selecting one updates the other. Any time a PC or bank message is sent to a device, the Dev PC buttons will update to reflect the new numbers. If an IA button has a CC0 or CC32 action followed by a PC action as the first two messages, or just a PC action as the first action, and IA Link is turned on, the IA button respond to other IA buttons and the Dev PC -/+ buttons. For example, a button that sends PC 10 to a device will automatically turn on when PC 10 is sent to the device, even if it was sent by another button.
- The MIDI Merge setting has been broken into In, Out and USB settings. You can use these to choose which ports are forwarded to the output, and which aren't. If you were merging from the In to the Out port, you will have to manually turn on the Merge: In setting after upgrading to this release. The Out setting is new and allows the input side of the bidirectional MIDI Out port to be forwarded out the MIDI Out port, which wasn't possible before.
BUG FIXES:
- Fixed drag-to-swap feature - it didn't work correctly when dragging to external switches
- Fixed some CC values for Strymon pedals
- Fixed special characters in preset, song and setlist names
TO UPDATE FIRMWARE:
-OR-
