I want to use a couple loops for pedals, send to the amp on loop 3 and connect amp effects loop to return of 3, then split the rest of the outputs to rack effects that will output to a mixer which outputs back to effects return. So far this is not working. Does the MEGX allow a combination of closed loops and open loops?
Specific setup:
Loop one split mono: 1 and 7, both pedals
Loop 2 send to rack unit and return from rack unit
Loop 3 send to amp input and return from amp effects send
Loop 4 split mono: 4 send to mixer, 10 send to rack effect input (which outputs to mixer)
Loop 5 split mono: 5 and 11 send to rack effect inputs (which output to mixer)
Loop 6: send to rack effect input (which outputs to mixer)
Loop order: 1 7 2 3 4* 10* 5* 11* 6*
*loops 4 and onward use send only, return disconnected
Specific setup:
