Yos Tanaka
I'm using Master Mind LT and Effect Gizmo.
I would like to know the MIDI PIN wiring for MasterMind LT.
Thank You!MIDI Output:
Pin 1: Bidirectional MIDI input + (connect to pin 4 on the other side)
Pin 2: ground
Pin 3: Bidirectional MIDI input - (connect to pin 5 on the other side)
Pin 4: MIDI output +
Pin 5: MIDI output -
Pin 6: Power
Pin 7: Power
Thank You.You can use either 9VAC or 12VDC, the LT will accept either.
Correct.Thank You.
Effect Gizmo's MIDI phantom power outputs 9V AC when using a 9V AC adapter, and 12V DC when using a 12V DC adapter, right?
And I'm sorry many times....I have an additional question.Thank You.
