Hi - I got a Mini Effects Gizmo last week and it worked fine at first. Then yesterday it suddenly developed a problem receiving MIDI information - sometimes it works fine, then nothing. When it's working you can program ok and it receives PC commands fine; but then other times you can't reprogram patches (presumably because it doesn't know it's received a new PC command) and it won't change patches (again, presumably it doesn't think it's received a PC command). Even more wierdly sometimes if I keep pressing on the relevant MIDI PC pedal the ME Gizmo suddenly changes patches as commanded (but it might take 3 or 4 repeated presses of the relevant program change pedal on the foot controller). So it seems that sometimes the MIDI messages are getting through, other times they're not.
I've done all the obvious things - changed MIDI leads, checked the relevant send/receive MIDI channels on everything, plugged the unit directly into my MIDI controller (a Yamaha MFC10) rather than via my MIDI distributor, etc, etc. I've also had a Mini Amp Gizmo and the larger Effects Gizmo, which I've used for a good year or more, so I know my way the RJM units pretty well now and can be as sure as I can be that it's not 'user error' on my part. Besides, they're both working fine, as are the two Eventide 'Factor' stomp boxes in my rig. (I got the Mini Effects Gizmo so I could better program the things I use in my amp's FX loop).
Any suggestions of things I could check/try ...? Kinda pulling my hair out here.
Thanks all.
Spike
Thanks all.
Spike
