Antoine from Belgium, I'm new here.
I wondered if there's a possibility to adjust the mix % on the mixer ?
Or is it set to a fix value ? let's say 50 % for example ?
It's certainly nothing I've ever had an issue with. I use the volume control on the Mini Line Mixer as the overall master volume for my rig... I set the levels in my FX on a preset-by-preset basis to get relative levels, then when I'm at the venue I adjust the overall FX level using the output volume on the processors to suit the ambience of the room - some rooms I find I need more effects than others.
