MLM and split with RG-16
joe web
hi ron,
you explain in your manual, that you would recommend an RG-16 to split the signals going to the effectsunits until it comes back to the MLM.
but how do you do that split? e.g. a split for three effects?
how should this be wired up with the RG-16, i can´t imagine it at the moment who this should work.
thanks
joe
If you use the loop sends and leave the returns open, then the signal will always pass from one loop to the next. This makes the loops work as a multi-way splitter. Turn the loop on and signal goes out the send, turn it off and the send is muted.
So, the loop send goes to the effect input and the effect output goes to the line mixer output. Please note that if you're using loops 5 through 8, you still need to connect the output of each loop to the input of the next.
ron, does this work with all loops? especially with loop 1-4 as well?
that´s interesting, that the signal passes by to the output jack of loop 5-8, didn´t know that.
thanks.
It works with all loops on both the RG-16 and Effect Gizmo, as long as you don't plug anything into the loop returns.
