Hi there,
I'm considering buying the amp gizmo and either a G Major 2 or a G system to streamline my setup and get rid of my tap dancing routines. My question is primarily regarding the G major unit. I know that it is possible to program the G system as a midi footswitch and then use it to control both the amp and FX repests at the same time.Hover i'm not sure if this is possible using the G Major 2. All I want is to have my amp channel selection linked to the FX patch of the G Major 2 so they switch together. I'm currently using a Fryette (VHT) Pitbull UL and would ideally like all five of the footswitch buttons reasigned on the midi board.
Also if the G Major can do this with the amp gizmo , would the standard Behringer FCB1010 footswitcher be ok for this task and will the Amp Gizmo power it?
Thanks in advance for your help.
