I think this will work, I just want some input.
I'm currently using an RG-16 with my Mesa Mark V, G-Major 2, and a couple stomp boxes. My guitars also have piezo systems installed and I'm using an insert/split cable at the "From Front" jack to split the stereo signal to magnetic and piezo.
What I'd like to know is if I can use Loop 8 to choose between destinations for the piezo output of my guitars. Here's how I would connect everything:
Guitar is plugged into the front RG-16 input and is split at the From Front output to the buffer and loop 8. My magnetic signal continues from the buffer and is irrelevant from here out. The piezo signal is plugged into the Loop 8 input. Loop 8 send is patched to a DI box, and Loop 8 output is patched to my acoustic amp. Nothing is connected to Loop 8 return
If this is correct (and appropriate), when I turn on Loop 8, the piezo signal should be routed to the DI box and when I turn loop 8 off it should be routed to my Acoustic amplifier.
