Wheresthedug
Hi guys,
I am trying to set up a preset with an 8th note delay at 126bpm in Timeline but I also want a super slow High Pass filter sweep in Mobius. Mobius tap divisions only go as long as Whole notes and even that is way too fast for what I want to achieve. I can get a pretty good sweep with Whole notes at 25bpm. However, if I send midi tempo info from PBC to set Mobius sweep at 25bpm Timeline also changes it's delay time to 25bpm.
What is the best way to achieve the right effect?
The options I can think of are:
1 - don't send any tempo info from PBC and simply store the tempo's in the Strymon presets. That would work but I might want to send tap tempo to the delay if the band shift tempo slightly.
2 - find a sweep tempo for Mobius that roughly matches a multiple of the delay times/tap division in Timeline. However, Timeline only goes to 16th notes so the slowest Mobius filter sweep I could achieve would be whole notes at 63bpm.
3 - set song tempo at 126 and sync Timeline to this. Accept that Mobius will be out of sync but assign an expression pedal to manually sweep the filter in Mobius. However, I don't think Mobius HP filter sweep can be set to manual mode.
Is there are way to send different midi tempo info on each midi channel from PBC?
Is there are way to turn off tempo info on one or more channels at a preset level?
Perhaps I could set the preset to not send any midi tempo so that the tempo from the previous preset is retained on the Timeline and the tempo for the preset is set correctly in the Mobius patch?
How would others set it up?
I'm sure Ron has a simple genius solution for this that I just haven't thought of
