CohesivePanic79
Any tips on cable setup for running an MXR Joshua in one of the stereo channels?
If I run it mono, it works fine.
The manual for the pedal gives steps to run stereo out. It says you can use a TRS splitter going from out to left and right. So I assumed that I could just use a straight TRS cable and run out to the return of my loop.
I also made a ring disconnect cable for the loop send/pedal in.
This doesn't seem to be working correctly. I only get delay if I have Echo 2 enabled. Primary echo isn't coming through.
Any ideas?
Any ideas?
