betweenus
Update time!
Things haven't changed that much. But as I've played with this setup, live, I've refined it so it works better for me during performances for the main pages. And then I've got a new page that's mainly for home use and you'll see why.
Page 1: Main
The major changes from the v1 release are along the top row and the bottom. On the top I've double-stacked some things. The Tempo >> Tuner button does tap tempo and hold-to-tune now. That freed up the upper left hand corner button. It's now used to get me to the looper page with one tap. I'm using the looper more and more with my band so this was handy. And hold for "Safe" gets me back to my main preset if I wander too far from home.
Along the bottom row, every scene button is now hold-to-bring-up-scene-selection. Any of them. Hold it down and you'll get the scene selection screen which is easier than reaching up to the top row. It's so much easier to hit literally any of those bottom row switches and hold it down to get to scenes 7 and 8 when I'm playing live.
Page 2: Special
Just some rearrangement and effect swaps on this page. Amp EQ toggles CC#15 on/off. I just always use that CC# for AMP EQ and it makes sense. Volume Pedal is a neat switch. Hold mode brings up channel selection for the VOL1 block and it names channel 1 "Pedal" (because it expects that channel to be tied to an expression pedal) and channel 2 is "Swell" (because it expects that channel to be set up in autoswell mode). That's pretty neat.
Page 3: Looper
Looper controls along the bottom should be self-explanatory. The row above the looper controls is setup for performance. Those are common blocks I like to toggle on/off when I'm looping with the band. And then the row above that one is setup for auditioning amp and cab settings. I can quickly turn amp blocks off/on and switch the cab block channels to try out different sounds while a loop block setup in front of all of them loops a lick. Upper left hand corner switch on this page gets me to the Main page.
Page 4: Buddy
This page is optimized for working with Buddy Gill's preset pack. I love that pack. It follows his recommendations for how to configure an FC-12 for use with his pack. The switches are named to follow the function of the block as Buddy intended it to function in his presets. For example, SC Boost engages a boost Buddy intended people with single coil guitars to use on presets that were dialed in with his humbucker-equipped SG.
Page 5: Utilities
All the stuff I need to maintain the GT-22 when I'm away from the editor. The Out + and Out - buttons increment/decrement OUT1's output level and save the changes. Careful using them. If you've tweaked the preset and use one of those switches you'll commit the changes along with the volume change. While I'm here I'll reiterate my request to @rjmmusic for a "get preset names and scenes from current preset" function I can assign to a switch that just updates the current preset in the GT-22 from the current preset in the Axe-Fx III.
You can grab the updated rjs file here: http://j.mp/2TEOTOg
That's it for now. Hope everyone is having a good summer making music!
Thank you for sharing, this is very helpful.
Keep up de great work
