Hi there!
I just purchased an RG-16 to use with a new system I´m bulding around a Bogner XTC. The idea is to put 4 pedals and a Line6 Mod Pro in front, and the Line6 Echo pro in the FX loop of the amp.
First thing I noticed is that the RG-16 makes a ground loop noise when only trying one loop (loop 1 or 2 tried so far) with one pedal. The noise will go away if I patch in the Buffer. This is all adressed in the manual, where it says to either use the buffer or "make" a ground lift. I don´t know how to do that so I´ll go with the buffer, but I´m worried since I intend to use a Fuzz pedal in loop 2.
Another question I have is regarding the use of the RG16 and the amps fx loop. I figured all I needed to do is just patch the fx unit into the amp´s fx loop, and then just engage the ON or OFF of the Fx´s loop via a functionl switch but then I saw the demo schemes, and it is recommended to insert the FX unit in the RG16, which I don´t really understand why. Is this an option, or is it really better to use it through the RG16? I just think the more "patching" and twisting of cables, the more noise I might end up getting.
Also, anybody there using an RG16 with a Bogner? Any ideas, suggestions would be welcome!
Thanks so much!
Thanks so much!
