IMakeBourbon
Hello every'all,
From Cincinnati and posting here for the first time, thank ya so very much. I'm trying to link up two Mini Amp Gizmos to control a pair of 1990s vintage VHT (now Fryette) Classic (aka CLX) 2x12 combos. I'm planning to make some DIY cables to connect the MAGs and the amps because it has been a real tough year. Shoutout to the staff at RJM who have been very helpful.
Here's my question. The VHTs have five footswitch functions (rhythm, lead, boost, EQ, and loop) and a 6 -pin jack on the amp chassis, and the shield wire per RJM's pinout solders to the #6 pin. So no problem, I'll go and solder that up into a cable, with a 6-pin DIN at the amp end and an 8-pin at the MAG end. Except, now that I think about it...the MAG is eight-pin. It has eight wires in play, but only five of them are controlling functions in the VHT amp. It can control up to eight functions.
Could I—
• install a new 8-pin DIN in the VHT chassis,
• install an 8-wire DIN at the amp-end of the cable, wire up the five footswitchable functions per usual there,
• break out the other three wires from the chassis 8-pin DIN, inside the chassis, to control other functions in the amp, not currently footswitchable?
Such as the spring reverb, which has a 1/4" footswitch jack under the chassis but is not controlled by the 5-function footswitch. I'd have to figure out how to wire those into the existing functions (and some of those functions, like pentode/triode power amp operation, are only controlled by a rocker switch at present; and others, like depth/presence circuit, are not switchable at all). But the way I see it, if the MAG controls eight functions, why not try and take advantage of all eight wires? Thoughts?
Cheers—
Could I—
Cheers—
