Odd Effects Gizmo Behavior
Discussion in 'Effect Gizmo / RG-16 / Rack Gizmo / Mini Effect Gi' started by Karsten Fliegner, Mar 2, 2019.
  1. Karsten Fliegner
    Karsten Fliegner
    Jan 11, 2019
    6
    0
    When sending MIDI CC commands from my Axe-Fx III using the MIDI block I can activate loops 1-8 (CC #s 80-87), but not 9-12 (CC #s 88-91). This is the case whether I run my TS to TRS cable from Output 5-8 to In 9 or from CS out to in 9. I tested literally every loop with the same MIDI block, using the same Channel.
    Anyone have an idea what might explain this?
    Thanks,
    Karsten
    #1 Karsten Fliegner, Mar 2, 2019
  2. rjmmusic
    Staff Member
    Jan 18, 2010
    5,211
    891
    Sounds like the CC numbers are not configured correctly. Loops 1-8 are configured to a range of CCs as a block, and loops 9-12 are configured as another block. Make sure they're set to the CC range you expect. Effect Gizmo manual pages attached for reference.
    Karsten Fliegner likes this.
  3. Karsten Fliegner
    Karsten Fliegner
    Jan 11, 2019
    6
    0
    Used setup mode as described and that took care of it, thanks! Strange, because I can't recall ever having changed the default settings, nor can I imagine a reason to.
Share This Page
