Lucas-Sharp
Hey all,
I have finally hooked up my pedals, pbc and kemper and I was just looking for some help as to how It's been done.
For starters this is how I am connecting the pbc to the kemper.
PBC Output 5-6 > KPA Alternative Input
KPA Output/Send > PBC in 7-10
PBC Output A (Left) > KPA Return
(Should be the rights series of connections, correct me if its not?)
Between those connections is a free the tone signal junction box to tidy it up moreso as well, with the midi also going into the signal box and coming out to an RJM phantom power box that sits next to the kemper with the midi out and in connected.
I am having trouble with hearing no sound from my strymon effects in loop 7-10 and hear only very lacking effects from the OD/ect pedals from 1-4.
All while this is happening, the signal from the guitar/pbc only comes through a straight clean signal and ignores any kemper preset I am on wether it be clean, dirty, etc.
And yes, the "Mono > Stereo" and "Mono Output" buttons on the back of the PBC are out.
I have the X effect set to stereo loop since that's the only way I get sound of course, although it seems to not acknowledge the actual preset or play these strymons effects at all, what could be done wrong?
There's also an issue with the kemper going from its main outputs into my Scarlett 2i2 and only really showing a consistent signal from the right input and is barely flashing nor indicating for the left. I think it could be to do with how it's setup with the stereo loop as I have tested all solderless/soldered cables used individually and they work just fine.
Any ideas? Would need help from anyone who is alright with kemper configuration as well just to help me get both worlds.
Help is much appreciated as I am a massive noob who still needs to tackle setting up presets and being able to change effects in syncopation with kemper presets with the PBC!!
