Thomas Hopton
Hi all,
Experiencing a weird midi issue in controlling the CXM 1978 automatone format pedal. I have the pedal added as a midi device to channel 2. It is able to receive correct PC messages to reflect presets. HOWEVER, it is unable to receive CC messages correctly. When sending CC messages for Bypass (102), or Mix (18), or Save presets (27) - none of these changes reflect on the pedal. In order to Save presets, I must save them on the device. None of the CC messages are registering when sent from my presets in the PBC Editor.
Some troubleshooting I've done on my end:
1. I've tried swapping out MIDI cables - same issue
2. I've started a brand new RJM test page - same issue
3. Deleted a re-added the device - same issue
4. Tried turning off and on the Update State on Preset Change and Send one Preset Change - same issue
Starting to get a bit confused here, and was hoping anybody could jump in if they have any ideas what could be the issue.
My MIDI routing -> PBC MIDI splitter cable from BTPA > Disaster Area MIDIBOX 4 (2 Jackson pedals) > MIDI THRU > CXM 1978 MIDI IN > MIDI THRU > TIMELINE MIDI IN > MIDI OUT > PBC6X
I've also attached some screenshots to see my setups.
