Hi all !
First a HUUUGE thanks for you RON for this marvelous piece of gear that I consider as a blessing on my musical way.
I just received the PCB 6X a few days ago and I've been trying for 3 days non-stop to program it according to my ideas, reading a lot and learning from forum threads, the V 4.5.0 editor manual and youtube vids.
Basically I just want 2 pages : An impro page and a Setlist page where I'll load my band's setlist.
This post concerns only the Impro page that I would like to work as follow :
Basically one button on the page is for paging up to the other page (Setlist), and the other 6 buttons are for accessing sounds quickly as needed in an improv context.
For that, the other 6 buttons all have local pages. Meaning by that that they are of IA type, and have an action loading a preset with a local page.
When pressing on a button, it should display its local page which contains different presets on a single device controlled by midi.
For example :
Button 1 is "Comp" loading preset "Comp" and its local page has 6 different comp flavors of the Jackson audio "bloom" compressor.
Button 2 is "Fuzz" loading preset "Fuzz" and its local page has 6 different Fuzz flavors of the Chassbliss mkii.
And so on with my Drive, Reverb, H9 and EQ pedals.
The 7th button on each local page should bring me back to the Impro page and should be saving the one preset I chose from this specific local page, so that I can be able to put together any combination of those 6X6 (6 buttons loading each of them 1 preset local page containing 6 "device presets") = 36 sounds that I could access with a few footswitches on the go.
The 2 problems I am meeting in the implementation of this idea are :
1. Local page won't display when I switch on buttons on the impro page (The "local page" option is sure ON in the preset tab and the "show page" option is set to "local page". Nevertheless they do display if I check the "Auto page select" ON on the system setting option in the Global tab, but it is said in the tooltips that they should display regardless of this option. (I don't want this option checked because then on startup it loads into a local page straight away and I wanna stay on the impro page on startup. I wouldn't mind it if I could counteract this single thing with a startup macro (because I like to have the Auto page selection on my other "Setlist" page but I've tried many different things and I just wasn't able to do it. Of course I had the "startup macro" option set to the corresponding macro number in the system settings)
2. Is there a way to get my selected preset on a local page to be saved when I step on the 7th "back to impro page" button, and still have it running even when I enter other local pages, so that I can add, remove and combine all these sounds to my wanting ? I have been unable to do it so far..
Thanks to you all a lot. For your time reading my thread and the support of this community
Attached my mastermind file
Pierre M.
For example :
Pierre M.
