When I use the loop 7 and the loop 8, (they can be controlled by the CC 55), the loop don't turns on, they don't repond to cc 55.
Can you help me please.
I test your tip, in the setup mode, only function loop 3 was on, the fonction loop 7 was allready off. I don't understand. In the manual, page 8they explain for the pairing of audio loops, but cc 52 to 55 don't respond for me, but all others works. weird. :cry:
Some news, i send the cc 55 nothing appen and when I send an other cc after it works, but I have the pairing audio loop 7 and 8, and an other audio loop, that I don't want. I think my RG-16 have some trouble. What can I do?
I have PM you the serial number. Can you tell me if it was allready in version 1.2, and if it was, can you tell me why he don't work properly?
Thanks for your help.
That's very strange - according to your serial number, you should definitely have the latest firmware. I tried it on an Effect Gizmo from the same manufacturing batch, and it works for me.
When you send CC#55, are you also sending it with a value greater than or equal to 64? Per the MIDI spec, values 0 to 63 are "off" and values 64 to 127 are "on"
If you have a PC or Mac with MIDI interface, I can tell you a Sysex command you can send to the Effect Gizmo to get it to report its firmware version.
I don't think it is that all other cc's work, but all cc's from 52 to 55, doesn't work well. I say that because I press the switch, nothing happen and when I press any other cc to midi channel 1 (RG-16) the stereo loop goes on. An it's the same to desactivate it.
Ok it's done, I've been fix the problem. I've made an other update on the rg-16 and it was ok. strange on the manual and with the date I bouth it, it was allready in v1.2.
But it's great now, I have got a nice Wet/Dry/Wet system. :mrgreen: :twisted:
