Proper cables for using mono pedals in stereo loop
Jrogg75
This could be already posted here.... but I wanted to make it obvious because I see this come up often. Here are the 2 cables you need to order from www.best-tronics.com if you want to use a mono pedal in the stereo loops WHILE RUNNING STEREO:
ADP31R-18 – Ring Disconnect Cable
ADP32R-18 – Mono/Stereo Converter Cable
These cables are NOT neccesary if you are not running a stereo signal in any of loops 7-10. But it absolute matters if you are. These cable ensure you get both the L & R signal chains going through the mono pedal!
Cheers!!
Jay
Yes, definitely correct. Thanks for posting the part numbers. Using those cables will allow the mono pedal to work in a stereo system. Please note that if the pedal is routed in series, you will lose any stereo separation that comes from pedals in earlier loops. Running the pedal in parallel will avoid this.
