Hi guys,
Just checking something with you all. I'm using my rack gizmo with an axe fx 2 xl+, Phantom power box and MMGT. I've noticed this recently and it has been intermittent until now as I've added a rack interface panel to my rack for easy setup and tear down.
Basically what happens is the rack gizmo will change amp functions on the front panel but my amp isn't switching. I tried plugging the amp interface cable straight into the rack gizmo and I had the same issue for a few minutes and then it started working. Same thing when plugging back into the interface panel it didn't work then it did work and now its not working again.
Could this be a faulty amp interface cable do you think? Or a midi setting?
I have the rack gizmo plugged in from the midi in to the midi thru on the axe fx and then a midi cable from the phantom power box to the midi in on the axe. GT is being controlled via a 7 pin midi to 6 pin xlr cable which works fine.
Any help or suggestions would be great.
Cheers
Paul
Cheers
Paul
