EVHGuy1111
Hello,
Setting up my Mastermind Rig. I'm loving it and setting it up how I want very easily.
I have a:
MEGX
PedalSnake 24' cable snake (runs to the board to connect my CryBay Jr. Wah to the backline where the MEGX is.
Problem is, I'm getting radical volume shifts when I change presets. Each preset has an amp channel change. I don't recall the volume shift when I first loaded the LT with the profiles I built, but it seems to have shifted the volumes when I started tweaking the amp's volume and EQ levels, but the volume swings aren't consistent.
One preset that has amp channel 2 will be louder but another preset with different effects but the same amp channel 2 will be quieter. Maybe it's only the presets with the CryBaby Jr Wah on it. If it is presets with the Wah which runs 24' from the MEGX, is there a way to boost that signal or will the MEGX buffer take care of it?
Or maybe it's the volume pedal I have in the loop? But then why would it make some presets quieter than others?
What is going on here? Kinda confused.
I have a:
MEGX
