Ron,
This is chris, the fireman that rudely cut you off on the phone yesterday when you were trying to help him Sorry about that, as I was on shift!
When we were talking, we were discussing my rig. While I definitely understand what you were saying, I was wondering if you could put it to me on paper with your routing charts? I have seen you do it a few times, but I wasn't sure if it was normal thing you do I know you are busy, but I would GREATLY appreciate it! Just for reference, heres what I think we decided on.
Dual amp set up with axe fx 4cm, and 2 or 3 pedals, using RG-16!!
First amp: (wet amp) VHT Ultralead and axe fx 4CM for all effects
2nd ampdry amp) VHT Deliverance (single channel no effects loop = EASY FOR ME TO USE! ) as my "Dry" signal, only pedal to be used would be the Maxon OD808. This pedal will be on at all times, whenever the Deliverance is in the signal.
I would like to be able to run both at the same time (both on for my rhythm tone) and seperate if I need be (again, Deliverance with boost on ALL the time) Basically, just doing the axe fx 4cm wiring diagram, with another amp added in with a pedal in front. I am just not quite sure how to do it, and would be much easier with one of your wiring charts you put up. I know you are extremely busy, but if you have any free time, I would be INCREDIBLY appreciative!
For now however, I do not have the axe fx, so the above is for at a later date (a month or so) when I get an axe fx. SO as of right now, the only pedals I will be using, is the maxon ts808, and a simple reverb pedal. The reverb pedal I only want to affect the Ultralead, while the 808 I'd like to use to boost both amps. If I choose to have it just effect the Deliverance when both amps are on, how much different will the wiring diagram look.
*Dumb noob questions of the day*
1. I plan to use a line 6 G90 wireless, that just plugs into the input of the RG16 right? Can I plug it into the "from front" on the back to keep all my wiring behind the rack?
2. When using a wah and the wireless, where does the wah plug into!? This one is making my brain hurt for some reason, I am obviously thinking too hard
Ron, thanks again for all your help, your customer service is bar none THE BEST!!!
