Screen Freeze
Discussion in 'LT General Discussion' started by johnnym, Apr 14, 2019.
  1. johnnym
    johnnym
    Feb 26, 2019
    11
    2
    Updated to the latest firmware. Experienced a screen freeze on two occasions. I am powered via USB. Will power from mains plug next time in case there is an issue with USB. Is this unique or has it been reported. Solution?
    Johnny M
  2. rjmmusic
    Staff Member
    Jan 18, 2010
    5,283
    914
    Can you describe the symptoms a little more? What do you see on the screen? When it happens, can you still get into setup mode?
  3. johnnym
    johnnym
    Feb 26, 2019
    11
    2
    I was changing presets and noticed that nothing at all was happening. Screen was showing Preset Page but none of the buttons were working, everything was frozen. I turned the power off by disconnecting the USB lead and powered back on...everything worked as it should.
    This has only happened since I updated the firmware and Editor.
    I thought possibly the USB lead had disconnected from the hub for a millisecond or so ....thus causing the screen to freeze? It has not happened since. Im guessing the USB lead pulled slightly from the hub and consequently the disconnection caused the buttons to fail??? I have plugged the USB Lead directly into the back of my MAC as the connection is tighter and more secure. I noticed that the USB powered hub connections are fairly loose in comparision to the MAC
    I don't think it is your firmware thats at fault but more a hardware problem....my USB hub.
    Will let you know if anything happens or changes
Share This Page
