Send all effects but one to two amps
Talesmusic
I have a pbc10, and I gig with a two-amp setup (a Hiwatt DR103 and a Marshall JMP 100). Since the Hiwatt stays very clean, I would like to use an overdrive in front of it (but have it before my boosters and modulation). Is there a way to send all my effects (but 1 - minus the overdrive) to two amps? The solution I have now is to go out from 'Out 1-4' straight to the Marshall (the OD is in loop 5), but then I also bypass my modulation effects. What is the best way to do this?
Unfortunately there isn't a way to do that. You can't run two signals (overdrive and no overdrive) through the same pedals. You'll either have to have a independent chain of pedals for each amp, or put the overdrive directly in front of the Hiwatt.
