eljodon
Here's part of my system setup and I wanted to know if this would work with the Mastermind PBC? This is just part of the set up in which loop 7-10 with have 2 Eventide H9 max, a Strymon Timeline and a Strymon BigSky. This a basic set up of the rack that will have the Effects Gizmo with the Noise reduction on loop 1, TC electronics Parametric eq loop 2, MXR 10 band eq, and the Sound Sculpture Volcano to control volume levels via PC# for lead boost and level differences between amps.
4 of my amps will be plugged into the Ampete 444 which you plug the amp inputs and speaker out from the amp. The speaker out of the Ampete goes into the Suhr Reactive Load and a line level signal will go into the Effects Gizmo so I can eq the signal with the TC Electronics 2240 parametric Eq and the MXR 10 band eq which will have a different eq curve so I can select between the 2 and the Volcano. The out of the the Effects Gizmo which will be the dry signal will go into the Mastermind PBC in 7-8 so I can blend the signal with the time base effects and the blend will come out of the PBC's output A Left and output B right which will go into the RJM mini mixer to control the system volume, then into a Mesa Boogie 2 90.
My question is, does this look correct? I just purchased the Mastermind PBC so I'm planning my system and I want to make sure I have it right or is there a better way? Sorry about the diagram it was done quick. Thanks
