touch33
hmmmmm...
I’ve read up on the programming/spiritual mapping connection required between my Mission SP1 expression pedal and my GT16 to control multiple vol/wah/whammy/trem-speed functions on my AFX3. SP1 is currently plugged into XP1/SW1 ports on GT16.
I think I’d like to use the SP1 toe switch to turn the pedal on/off, with the EXT SW1 “IA Linked” to a “regular button” labeled PEDAL. I’d like the “hold” feature of this PEDAL button to control an “IA Cycle” function that selects which of the four “purposes” PEDAL gets used for.
Questions:
1) are there any specific/recommended EXT controller numbers (in the AFX3) that typically get used for each function? For example, EXT15=wah, EXT16=vol, etc? Obviously, they need to match whatever routing is used in my Presets (mostly AustinBuddy, but there are lots of others), but I assume I can alter my PEDAL programming on a per-preset basis if needed.
2) in addition to the PEDAL button, I plan on using other specific block control buttons to determine which A/B/C/D channel each block is set to — a WAH button whose “hold” is an IA Cycle, a VOL button, a WHAMMY button, etc.
3) I’ve yet to figure out how the PEDAL button on/off function would be programmed, especially since I’d like it to turn ON to whatever the IA Cycle “hold” button is presently set to — so that if the PEDAL button “hold” shows “WAH” when PEDAL=OFF then pressing PEDAL=ON would activate only WAH and not the other three functions.
I’m sure that there are subtleties I haven’t thought of, or maybe even A Better Way to do this. Any suggestions/guidance/clues/links shall be most appreciated!
Cheers,
Bruce
Questions:
Cheers,
Bruce
