My whole system was working perfectly then I changed one item and I'm having issues. Here's my original setup
Loop 1 - Not used
Loop 2 - Overdrive Pedal
Loop 3 - Not used
Loop 4 - Talkbox
Loop 5 - electric guitar signal
Loop 6 - acoustic guitar Signal
Loop 7 - Guitar synth Left
Loop 8 - Guitar synth right.
I use one guitar with three outputs to mix the electric, acoustic, and synth signals. Only the electric signal goes thru loops 1-4 then to my amp. Acoustic and synth signals go direct to PA. Effects are rack unit in the effects loop of the amp.
All was switching fine until I decided to use two insert cables to put the stereo synth in loop 7 only and put my amp effects loop in loop 8, so I could put a volume boost pedal in the send & return of loop 8 for solos.
Now when I switch from loop 5 on (electric guitar) to loop 6 on(acoustic guitar) the loop 6 light comes on but no sound is output. If I manually press the loop 6 button off, then on again sound is there. I also noticed that if I switched from loop 5 to loop 6 and turned on loop 8 (the boost) even though the acoustic signal does not flow thru the boost, then I would have acoustic sound. It did the same thing with turning loop 7 on at the same time as loop 6 and I would get sound. Only when loop 6 was turned on by itself I would get no sound.
Any ideas as to why? I checked, nothing is grouped or momentary. I checked my midi programming and don't see any obvious mistakes. Should I try a system reset? I'm using the power supply that came with it. I hope my description makes sense. Appreciate any ideas.
Loop 1 - Not used
Loop 3 - Not used
Loop 4 - Talkbox
