gearhound22
Hi all,
I've got the RJM GT16 working with the AFX III but was going to make a backup rig with the II.
It was setup to copy the preset names from the III (I will keep identical patch names & numbers on the II so it will be identical)
So presets and back up/down is working fine.
The problem I'm having is I've setup two pedals as tap tempo and tuner but these won't work when I try on the II.
Checking the GT I think the III was CC33 for tempo and CC35 for tuner (or visa versa) so I changed the CCs on the II to match but no luck....I'm using the RJM phantom power box so both midi/in out are connected.
Also is the tuner display possible on the RJM with this setup with the II like the III?
Hoping this is possible!!!
thanks!
thanks!
