edwinstar
Hi!
I have a Lehle D.Loop that responds to Program Change. I use it as a Tune/Boost/Bypass Box in my Setup.
I programmed three IA Buttons that send PC 1-3 to the Lehle. I put all three Buttons in Group one and have IA Link turned on. It works as expected while programming Presets with the IA Buttons. It also sounds as expected when recalling the Presets, but it doesn't look as expected: sometimes two of those Buttons in Group one are lit at once, even tough they are in the same group. So my question is:
- How can I make these three Buttons behave correctly?
Additional Question: As you all know there is the option in each Preset to send PCs to Devices directly. Am I correct to assume to not use this option for the Lehle when using the IA buttons to send the PCs?
Thanks a lot for your help!
Adrian
PS: I attached my Setup file
Adrian
