laurentius said:Is there a way to make the mmgt recall the last used preset when powering it again? Even better if this was possible in Setlist mode as well?
Thanks,
L.
Currently not possible, but it's a good idea!
Thanks,
L.
Johan Allard said:Also, how do I set the default button state for local pages? I have a preset with a local page, for some reason, it has decided that Scene 5 should be the default enabled. I unselect "Edit Local Buttons" in the Editor (Mac), click on Scene 1 which is now enabled, enable "Edit Local Buttons" and Scene 5 has now been selected again???
rjmmusic said:Just last night, I found some issues in the editor and I'm just about to upload an update - it may help with your situation.
Johan Allard said:rjmmusic said:Just last night, I found some issues in the editor and I'm just about to upload an update - it may help with your situation.
You might have fixed a different issue then
Have a look at this video: http://youtu.be/AVSsyCL0Q3s
I have a few scenes on this local page. I cannot make scene 1 the default in the editor or on the device?
Johan Allard said:With the page issue, I was thinking I could just spend some time in front of the TV to copy a page to the local page on all factory presets. Are there any local page limits or similar that I should be aware of?
rjmmusic said:Ok, I see now. The buttons are set to be controlled by the Axe-Fx, and not by the GT's internal settings. On the actual GT, the buttons will report whichever scene the Axe-Fx is currently on. On the editor, it will default to the first scene always.
To change this, turn on the "Send on Preset Change" and "Update on Preset Change" setting for each of the scene buttons. This will make the buttons pay attention to the GT's internal memory. You'll be able to save the scene button state and the GT will make the scene change when you change presets.
Alexander said:Johan, why not assign button 2 to Scene Increment?
There's a dedicated CC for that.
