Lewis Fischer
Hey all, finally got my PBC 6X and pedalboard wired up and am working through some kinks to get it all working as intended.
I'm using the PBC to control a wet/dry rig (Orange Rockerverb 50 MK III/Orange OR50).
1. Possible issue/routing:
The critical bit which I need to get right:
Insert Send: Splits with an insert cable and goes to: AMP 1 via Blooper / AMP 2 via Lehle P-Iso for galvanic isolation.
Insert Return: Goes to FX SEND.
Out: Goes to FX RETURN.
Would I be correct in thinking I need to set Insert Send to Stereo in the editor, and this should technically all be good?
I have only tested summed to mono with one amp so far, pending access to an extra speaker cab.
2. External switches:
I'm having a bit of trouble setting up an external switch to do what I want it to do.
I purchased an American Loopers switch with the LEDs setup for the PBC.
I want to program this to basically kill one amp and leave the other on.
When I go to program this I can select an IA action as Insert/Number: (presumably 1 for Amp 1 and 2 for Amp 2) etc.
Have I misunderstood this or should this be correct?
3.
Pic for context/something to look at, although I don't think it'll be much help in diagnosing any foreseeable issues:
3.
