Y-Not v1
daboomer
Could a Y-Not v1 be used to split my signal after my dirt pedals, sending one out to a dry amp and the other back to my wet pedals for a wet/dry/wet rig?
Want to then be able to use presets on my PBC to send midi messages to Y-Not to switch between wet/dry/wet and stereo (using the two wet amps).
Will this work?
Y-Not arrived today (purchased used on Reverb). Hooked it up. Created PC +/- buttons on the PBC. Programmed desired presets on the Y-Not (dry only, wet only, and wet/dry).
Works like a charm. Pretty darn awesome.
