Amp Gizmo Momentary and Invert Modes at Same Time?
Coalface
Hi Ron,
Is the invert mode and momentary mode able to be used simultaneously with Amp Gizmo?
Have an old Amp Gizmo I'm intending to use in a rig build, along with my own version of a BOB-8 I'm most of way finished with building.
The rig has a Mesa Headtrack headswitcher, so I'll be needing to isolate the Amp Gizmo function relays to keep the grounds of the amp function switches on their respective sides. Hence the need for a BOB-8.
Cheers
Chris.
Yes, you can set a button to be both momentary and inverted. That means the switch will normally be on and will turn off for a short period when activated.
Coalface
Hi All,
Finished my own BOB-8 box. Hope it is alright to cross post the info, Ron.
Here is a pic of it in the rack I'm nearly done with. The other box is a patchbay for the Headtrack's FX loop patching, and MIDI I/O to the rack.
Old Amp Gizmo at the front.
Coalface
Thanks Ron.
Have a couple of other mini-Amp Gizmos, and will do at least another one. Simpler design though next time lol..
Chris.
