wire_twerp
Hi there
I'm tearing my hair out trying to get this freakin' delay to work with MIDI.
I've connected the Empress Echo to the MB2 using both TS and TRS cables - both are the same (non-functional). I've configured the Echo's control port setting to listen to MIDI, channel 2 (advanced configuration).
I've set the PBC Devices TAB to the settings that you can select from the manufacturers' pull down list, MIDI channel 2.
I'm using scrolling preset configuration not Bank.
The MIDIBox 2 seems to be OK as it is transmitting MIDI thru messages to my FM3.
I would be most grateful for any help. Thank you!
