Display Lights Change?
Andrealoud
I'm using the Overture with my PBC6x. Overture midi channel set to 6, PBC/Editor Set to channel 6 and assigned to the overture. When I change presets on the PBC, the display lights don't change to show that I have loaded a new preset. Is that expected behavior? I would assume that the display should change when a new preset is loaded. When the Overture is connected via USB to the PedalEditor and I switch between presets in the PedalEditor the indicators change ot show a new preset has been loaded.
Thanks in advance.
andrea
It should change to reflect any preset change, regardless of how the preset change is requested. Are you sure the PBC is sending a program change to the Overture? Is it changing audibly?
Andrealoud
I think I got it to work. I had not clicked "Active" on the PedalEditor. I clicked Active, wrote settings to device and it now looks (and sounds) like it's working. Thanks!
