MasterMind LT -- 9v pass thru
merkaba22
The idea is that you could use a powered 7-pin cable to the LT, where "excess voltage" can be "passed off" to the LT 9volt jack for powering associated pedals, for example.
Is there a mod that can be done?
It actually works that way now. It will only pass a maximum of 500mA before the internal fuse kicks in.
merkaba22
Sorry, its my brain sometimes ... Do I provide up to 500 externally via 7 pin, the LT uses up to 150, and the rest is passed on. Or can I provide 650 from an external source, where the the LT can lift 150 where the fuse is not blown passing on up to 500?
It's the latter, up to 500mA can pass from the MIDI jack to the power jack, as long as your power supply has enough capacity to power both the LT and whatever else you're powering.
