MASTERMIND LT FIRMWARE / EDITOR 4.4.0
Discussion in 'LT General Discussion' started by rjmmusic, Feb 11, 2020.
  1. rjmmusic
    Staff Member
    Jan 18, 2010
    6,057
    1,093
    Here's a new release for you, with some bug fixes and user requested features. Please test it out if you have the time!
    FEATURES:
    • Support for Strymon Iridium, Chase Bliss Blooper and Mood
    • Tapped in tempos are now preserved when switching presets within a song, if preset tempos are set to Song, or if "Ignore Preset Tempos" is turned on.
    • Added two special values to the ExpPedal action: "Same" does nothing, and "Send" sends the expression pedal's current value again
    • "Decimal Tempo" setting controls whether tempos are displayed with one decimal place or as whole numbers only
    • Added setting to reverse Bank MSB and Bank LSB CCs for incoming bank selection
    BUG FIXES:
    • Fixed button name display in IA Mode
    • Turning on "Update on Preset Change" on a button will now disable state updates from an Axe-Fx III, like it does on previous models
    • Kemper tuner and tempo now work even if Ignore Incoming CC is turned on
    • Fixed state update of Kemper Reverb button
    • Fixed a bug that prevented long Sysex messages from being sent over USB. (This happened when using more than one Sysex action to build a longer message)
    • Fixed Axe-Fx tuner that was off by 1 cent
    • Fixed warnings when running editor in MacOS Catalina
    • Fixed potential memory corruption issue
    TO UPDATE FIRMWARE:
    - First, back up your settings to a flash drive or computer! If you go back to 4.2 or earlier, your Mastermind will factory reset.
    -OR-
    - Use the Transfer / Update Firmware menu option to update the Mastermind. This works with LTs made after March 2019.
    Firmware: http://www.rjmmusic.com/downloads/PBC/MM440.zip
    Mac Editor: http://www.rjmmusic.com/downloads/PBC/MastermindEditor-4.4.0.dmg
    PC Editor: http://www.rjmmusic.com/downloads/PBC/MastermindEditor-4.4.0.zip
    Manual: http://www.rjmmusic.com/downloads/MMLT/Mastermind LT Manual-4.2.pdf (same as 4.2 manual)
    Editor Manual: http://www.rjmmusic.com/wiki (not yet updated for 4.4)
  2. Toopy14
    Toopy14
    Nov 1, 2019
    40
    0
    Updating LT firmware;
    "Please note: Firmware update through the editor is only available on Mastermind PBC and LT units built March 2019 or later."
    How can you tell when your LT was made?
  3. rjmmusic
    Staff Member
    Jan 18, 2010
    6,057
    1,093
    The easiest (and most accurate) way to check is to hold the 1 and 3 buttons as you power up the LT. You should get a message saying "Mastermind Bootloader". If it reports version 1.0, it's older. If it reports 2.0, it's newer and supports firmware updates through the editor. Restart the Mastermind to get it back to normal operating mode.
    Toopy14 likes this.
  4. Toopy14
    Toopy14
    Nov 1, 2019
    40
    0
    I have version 1.1. :-(
    Is there anyway to update the Bootloader? Is it ROM IC?
Share This Page
