JNPMusic
I have an expression pedal (Dunlop Mini X) hooked up to the PBC and controlling a BigSky and Timeline. I calibrated the pedal and all things are working. Then all of a sudden I look down at my BigSky and notice the effects parameter jumping around. Plugged in the guitar and played a bit and whatever the expression pedal is controlling say Mix on both pedals it's jumping around. Re-calibrated the pedal and when it gets to the toe position sometimes it goes full (say 10) and other times it won't go all the way over, just jumps around. I plugged the expression pedal directly into the BigSky and it works perfectly. When I get it to calibrate fully it sometimes falls short of 10 on the BigSky. (The BigSky displays the value as you move the expression pedal).
Seems like when it's sitting idle something is sending a signal, causing it to jump around.
