JohnnyIndia
How would I connect a GT22 to do the following:
A) Control Ableton Live as a Midi Controller through RME Fireface UC Interface
B) Be controlled by Ableton Live - Ableton will be sending midi clock, as well as preset change messages to the GT22
C) Control 3 Mini Effect Gizmos
D) Control an Axe FX
Not sure if its possible to do all of this at once and how I would need to cable the rig up with midi inputs and outputs
With the 3 MEGs, I will most likely be daisy chaining all 3 of them, with the final output from the 3rd MEG going to a Molten Voltage Midi Splitty to control some other midi functions on my effects (DD-500, Moog MF104M, Whammy V, and a Molten Voltage CTL Sync to send midi clock to some tap tempo style pedals). I may need to split the 3 MEGs over 2 pedalboards however, in which case I may have Pedalboard 1: 2 MEGs daisy chained with the final output to the Whammy 5, Pedalboard 2: 1 MEG with the final output to the Midi Splitty > DD-500, Moog MF-104M, MV CTL Sync (so I would need 2 separate connections form the GT22 to each board as all 3 MEGS wouldn't be daisy chained). Hope that makes sense.
Thanks for the advice!
