I'm not explaining the issue very well... I don't think it's an expression pedal issue because it happens on power up of the pedalboard. On initial power up, the BigSky is entering one of two states:
1) Maximum decay values -or-
2) Minimum decay values
Rebooting the PBC will eventually get the correct decay values to load on the BigSky, but Sunday it took literally 20 reboots of the PBC. Rebooting the BigSky has no effect on the state it's in (Max or Min decay values). In fact, it will power up with the correct value, but when a preset change is sent from the PBC it returns to either state 1 or 2. While in state 1 or 2, every preset change sent from the PBC to the BigSky remains in either that Max or Min decay value state. Now, when I say Max or Min, I'm not referring to the Max or Min range defined by the Expression pedal, I'm referring to the Max and Min ranges of the selected algo's in the BigSky. For example, on Preset 1 of Song 1, the max expression pedal decay for the BigSky is set to just over 3 seconds. When the pedalboard is powered on, the BigSky is either initiated at 20 seconds (max for that algo) or 500ms (min for that algo). The actual saved decay value for that algo is 7 seconds. Same thing on Preset 2 of Song 1, only the max value for that algo is 50 seconds!
